Turn on Maestro
wn
wn Member
Turn on Maestro by pressing  "RIGHT SIDE OF POWER BUTTON" ....The button is very small why Right side?
  • k3Tim
    k3Tim Member ✭✭✭
    edited May 2020
    The button your pressing is like a lever system that pushes on the actually on/off button for the internal tablet. Seems the right hand side (RHS) simple is at a mechanical advantage over the LHS.
    Size:  Seems reasonable considering one doesn't want to flase trip it on or worse off. By comparison the buttons on smartphones are small.
  • wn
    wn Member
    edited June 2017
    Thank You .
  • KF4HR
    KF4HR Member ✭✭
    edited June 2017
    The power button is actually on the top left (top of case).  If you're referring to the button on the right side labeled PWR, that's your RF power control.
  • wn
    wn Member
    edited June 2017
    I was referring to the left top button.
