Anyone knows how is air circulation Flex signature 6300?
YV5WZ
I'm going to place two 4 inches fan to refresh area where my Flex 6300 is, I'm wondering if right move is blowing or extracting air. As flex right side is open, I will work on left side which towards to wall.
All this is my "sweet wait" for Flex 6600
thanks for your advises and recommendations
George, YV5WZ / PY3ZZZ
Air enters from the front and is exhausted via the rear.1
I use a laptop cooler here. They have two quiet fans in them and cool from below, even without vent holes, plug into a powered USB port1
Tim,
Is it better to push air through the front or pull air from the back?0 -
Don't go against the flow. It is easier to push from the front.
However, Keith's idea is very valid. A laptop cooler usually work well unless the ambient temperature is really high (+85F)1 -
Roger That!!.....Thank you! Tim...you're "The Man"
I have one ...!!! just one fan, but.....guess its gonna work
George
Pulling air from the radio would aid in dropping the internal pressure which would drop the air temperature and increase air velocity.1
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 41 Aurora
- 955 Maestro
