Two Cat Ports---- How is this done?
Ok, will try to explain this the best I can! Rig is a 5000a. I would like to be able to use both receiver's at the same time (dual receive) like the following. Main receiver set to 40 meters----listening to whatever
2nd receiver set to 40 meter cw mode using CW skimmer (this works ok but I cant get the Cat the follow in Skimmer.
I guess another way to say this is--- can you set up each receiver independently (each using there own cat port) OR---- one receiver set to 40 cw using Skimmer the other set to 20 cw also using CW Skimmer.
I down loaded DDUtil because I think I need to use it---- just now sure how to set is up?
Thank You
Larry
Larry, what you are trying to do is use the 5000 +RX2 as two independent radios. This is not an easy thing to do with PowerSDR because there is only one CAT port (interface) for the entire radio and the primary and second receiver appear as VFO-A and VFO-B on the same radio; not two radios (both being VFO-A). With DDUtil you can set up multiple CAT enabled programs to interface with the radio. But for what you are trying to do, you need to force CWSkimmer into thinking it is controlling VFO-B and I do not think that is possible.
I know this is of little consolation, but what you are trying to do is incredibly easy to do with any FLEX-6000 radio because the CAT interface was designed to interface with the radio in such a way that each slice receiver is treated as an independent radio. On my 6700, I have run 4 instances of CW Skimmer on 80, 40, 20 and 15m simultaneously and all track perfectly using the SDR-Bridge interface. I can mouse click on either the CW Skimmer waterfall or the SmartSDR panafall display and the radio tunes properly and CW Skimmer tracks properly. SDR-Bridge also has a feature to change the transmitter to the slice that I most recently tuned, making this setup essentially a point, click and work on 4 bands without changing anything on the radio (assuming my ATU already has a memory defined for the transmit frequency).0 -
Thanks for the information Tim! Yes I will upgrade in the near future as it appears that interfacing different software is much simpler using SmartSDR.
Will wait a while as I think a lot of folks are curious as to what will happed to the older 6300,6500 and 6700 radios.
Best Regards,
Larry
Nothing is going to happen to the 6300, 6500, 6700 except they will continue to receive SmartSDR software updates and continue to get better,1
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
