Higher Res Screen for Maestro?
edited June 2020 in Maestro
I'm curious if FRS plans to upgrade the 8 inch display in the Maestro from its current 1280x800 resolution, to the higher resolution 1920x1200 display used on the 6400M and 6600M, and if so, will the newer display be made available for the older Maestro's?
Welcome!
  • Member, Super Elmer Moderator
    edited June 2020
    They have not any upgrade to the Maestro. The higher resolution displays will be available on the M series radios.
  • Member ✭✭
    edited June 2017
    Yes, I know.  I'm just wondering if FRS has future plans to upgrade the Maestro screen?
  • Member ✭✭
    edited June 2017
    I think it is very likely that we will get a "Maestro Mark 2" based on the front panel and Hi-resolution display that we see on the M models sometime after the Ms are initially shipped. It is likely that Flex uses a sort of standalone circuit board of the Maestro inside the M cases that would be easy for them to adapt for full Maestro-like functionality.
    If they ever decide to include mouse-based clicktune, I might even be in the market for one.
    Jerry W4UK
  • Administrator, FlexRadio Employee admin
    edited June 2017
    KF4HR - These types of questions will not get an answer from FlexRadio.   It is the policy of FlexRadio Systems not to discuss, speculate or make any forward-looking statements regarding new products or services until they have been officially announced.
