audioengine A2+ Pop every 3 seconds on 6500 NO AUDIO
mark Caton
Using Audioengines A2+ on my new 6500. Neither USB hookup or PwrSpk in rear of 6500 keeps the speakers from a POP every 3 to 5 seconds and NO AUDIO. I am brand new to SDR and owning a Flex. Thank you for your time and PATIENCE. I am going to need it, But will persevere!!!!!!!
I do not own the speaker brand you mentioned but I have seen where having the gain on the speaker too high can cause this. I think the pop is because you have driven the amp in the speaker to overload. Just a thought!0
Hello Neal: Thank you for your input and I will DOUBLE-CHECK my settings tonight. Its probably OPERATOR-MALFUNCTION, as usual. Mark-W6WWA0
I have the AE-A2 and have the volume set to about half, have been using with no issues for several years now....0
Again, Thank you for your thoughts and I will be checking my settings tonight. I will be in-touch. Mark0
Mark
Make sure that the audio level coming out of Smartsdr is not too high, that could also be the cause.
730 -
Or the impedance level of the device connected to the 6000 is too low.0
To K0eoo/K3NC/W4TME: I finally found the problem!!!! There was a short at the plug-in to the speaker jack (3 Prong) that goes into the speaker. I have other A2+ I use and so replaced a few things and found the culprit. Appreciate all the help and thoughts as to what might be the problem. Audioengine is rushing me out a new power cord/3 prong. Thank you again, Mark---W6WWA
I am sure you will be hearing from me soon
- 378 Community Topics
- 117 SmartSDR+
- 37 Aurora
- 946 Maestro
- 923 Genius Products
