dstar - No Waveform out or Decode
James Nelson
Dstar waveform on TX not happening, there is no waveform evident, also using an ICOM 7100 to TX (and RX) on any given freq to Flex6700 there is no decoding. Ver 2.10.16.174 Dongle DV3000U (Nth West Digital Radio) USB Ports on radio swapped multiple times with no result. Realising its early days and as other priorities come 1st I have left this until now. Not urgent and will wait patiently for a resolution. thanks guys ! Note I have not seen it work at all since I acquired to the dongle directly from NWDR 1 year ago.
@James Presumably you can select the DStar waveform from within SmartSDR, so moving past do you receive but not transmit DStar or? I found installing the dongle a fiddle and it needed redoing when I upgraded SmartSDR versions. I reinstalled the waveforms but have found so little traffic that I've not done much with it. 73 Steve K9ZW0
I took a suggestion from Dudley and reverted to SmartSDR version 1.9.13 and D-STAR Waveform version 1.07. I am able to decode most received signals of S8 or better and the transmit waveform works as evidenced by several 2 way contacts during the HF D-STAR testing net this morning.
It would be nice if Flex issued a fix for this so that it works with the last version of SSDR .. it has been going on for FAR too long. The ability to to do DSTAR was one of the main factors in my purchase decision.
Andy K3UK1 -
Hi Andy, It seems FRS is at the mercy of North West Digital Radio who dies the DVDongle. While not my main radio purchase reason I had hoped to get some experience out of the DVDongle but it hasn't been so. I don't know if the **** had been updates since launch (late 2014?). Perhaps FRS can prod the NWDR folk into getting their Dongle working. 73 Steve K9ZW0
I doubt that it has anything to do with NWDR. It used to work fine with older versions of SmartSDR but broke when FRS updated SmartSDR.
I think this is just a case of FRS prioritizing their programing issues and DStar is not high on their list. Their focus is on new hardware and SmartSDR 2.0.
Lets hope it is fixed in 2.0. I also bought my radio because I wanted DStar. FRS has really ignored this issue due to other priorities.2 -
Could be some more broken with the last update, but it sure wasn't working correctly on all bands before either. That stuff was understood to be a problem in non-FRS software, but who knows. It was pretty low on the priority for me, so I've kind of ignored it. In our area we sudden have some C4FM/Fusion traffic and equipment as a further distraction. The DVDongle launch left one with an expectation that more would be added in terms of capabilities and what didn't work would get fixed. Seems to have slid back instead. 73 Steve K9ZW1
I have tried old Ssdr versions, cold swapping hot swapping and no waveform TX or Rx. Being a realist I know this will be fixed in the priority it deserves. We have a group playing quite a bit with Dstar mode AKA ambe mode on IC7100 and IC9100 HF nets here in Australia aside from FreeDV so it sure would be nice to work. I see the Dstar connection "my call" & "your call" protocols have been laid out well so the post here is a soft reminder to FRS there are users out there playing with this. My dongle was ordered direct from NWDU. I patiently wait thanks everyone0
This issue has been previously entered into our bug tracker as defect #4457. Thank you for the defect report.0
- 378 Community Topics
- 118 SmartSDR+
- 193 DAX
- 38 Aurora
- 257 FLEX-8000 Signature Series
- 947 Maestro
- 924 Genius Products
