20Hz Offset between CWSkimmer & N3FJP Amateur Contact Log using SDR BRIDGE & F6300
wb3fsr
Have any of you achieved ZERO (0) offset with this combination of software? Have not found method to net them closer.
Flex 6300
CWSkimmer ver 1.91
N3FJP ACL Series of logs latest vers
SDR BRIDGE 1.5.1.124
The 20Hz offset easily falls within the passband. More of an annoyance than a show stopper.
TIA
PeterV WB3FSR
Where is the error indicted? CWSkimmer does not have the same frequency resolution as the radio. the FLEX-6300 has a minimum 1 Hz resolution. CWSkimmer has a minimum 10 Hz resolution. Therefore there can be rounding effects that show up as a frequency mismatch. If you are feeding a third-party app frequency data from CWSkimmer, that is where a mismatch can occur based on the "dial" frequency of the FLEX-6000.0
Tim,
Thanks - makes perfect sense
PeterV WB3FSR0 -
Is the CW side tone setting same in both? Andy0
Hi Andy yes they are. Also tried offsetting them.0
- 328 Community Topics
- 594 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 397 SmartSDR for Mac
- 260 SmartSDR for iOS
- 247 SmartSDR CAT
- 179 DAX
- 369 SmartSDR API
- 9.1K Radios and Accessories
- 15 Aurora
- 162 FLEX-8000 Signature Series
- 910 Maestro
- 51 FlexControl
- 873 Genius Products
- 312 Tuner Genius XL
- 115 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 135 Contesting
- 726 Peripherals & Station Integration
- 136 Amateur Radio Interests
- 945 Third-Party Software
