20Hz Offset between CWSkimmer & N3FJP Amateur Contact Log using SDR BRIDGE & F6300
wb3fsr
Have any of you achieved ZERO (0) offset with this combination of software? Have not found method to net them closer.
Flex 6300
CWSkimmer ver 1.91
N3FJP ACL Series of logs latest vers
SDR BRIDGE 1.5.1.124
The 20Hz offset easily falls within the passband. More of an annoyance than a show stopper.
TIA
PeterV WB3FSR
Where is the error indicted? CWSkimmer does not have the same frequency resolution as the radio. the FLEX-6300 has a minimum 1 Hz resolution. CWSkimmer has a minimum 10 Hz resolution. Therefore there can be rounding effects that show up as a frequency mismatch. If you are feeding a third-party app frequency data from CWSkimmer, that is where a mismatch can occur based on the "dial" frequency of the FLEX-6000.0
Tim,
Thanks - makes perfect sense
PeterV WB3FSR0 -
Is the CW side tone setting same in both? Andy0
Hi Andy yes they are. Also tried offsetting them.0
- 654 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
