6400 .. 1/8 Mic connector only?
Dave Dave
Is this right, the new radios only have 1 mic connector and its a 1/8 inch connector?
Correct, only thing I have ever used with my HC4 Heil cartridge.
A couple of my friends are XLR users, easy to adapt.
I am sure flex will have an adapter ready soon.
I found one quickly at a vendor I use at work
http://www.fullcompass.com/prod/068827-Hosa-MIT-156
Yes, electrically it is an XLR connection. People are thinking a right angle plug is best in order to take the wight off the plug.
And check out the post, microphone connection on the 6600 down the board0 -
That adapter converts balanced mic to unbalanced input and also contains a transformer to step 600 Ohm mic to 2500 Ohm input.
http://hosatech.com/product/mit-156/0 -
For the new 6400/6600, what happens when you plug Heil headset which has 1/8" mono plug for the mic output in to the 6400/6600 mic input?? Also, what type of adapter will be needed for this situation?
Yep you're right Mike. I got the 600 ohm 1/8" part right.
Like i said, not an XLR user but I'm sure the proper adapter for the mic of your choice is available.
I too will be adapting the 1/8" as Bill said to keep the strain off the connector in the radio.
Everyone missed what I see as a problem, a 1/8 connector should never be used on something that gets pulled, its simply too weak. A L connector that barely sticks out might last a while.
I can only assume Flex saved .03 a radio by using it but with flex still not having something so BASIC as Squelch I cant say I'm surprised.
Here is a link posted a little while ago for a right angle 1/8" to XLR.
http://www.guitarcenter.com/Hosa/Stereo-35mm-Male-TRS-Right-Angle-to-XLR-Female-Microphone-Patch-Cab...
The post is
https://community.flexradio.com/flexradio/topics/microphone-connection-on-the-flex-6600
I like Ken NM9P's comment, makes most sense.
Here's a very informative read on the subject of audio connectors (XLR, TRS and others) and their
proper use to avoid ground loops.
http://www.rane.com/note110.html
Since the rear connector on the new radios is a "pseudo balanced" connector, it might be a good idea for all of us that are considering purchasing the new radios and wanting to continue to use our current microphones ( I have a Heil PRO 781) to read this article.
james
James that is the best illustration I have ever seen on the subject.
This is a must read. Thanks.0 -
I would prefer a 1/4 inch over 1/8th inch, but remember there is always some compromise. The mic I have plugged in right now is 1/8th inch. So I have to use an adapter. So I'm using pigtails and adapters because my microphones aren't all the same.
As for the squelch, I'm surprised that anyone uses them. I only use them on my FM HT's and Car radio. Even Icom uses a combo squelch RF gain knob that most of us switch to be RF gain only. But different strokes for different folks.0
- 113 SmartSDR+
- 920 Genius Products
