Part 1: Raspberry Pi SoftEther Server Setup for Remote Access to your Flex 6000 Radio
Hi all...
I'm generally pretty good with linux but I have run into an issue following this process.
At first I manually typed in the script and it seemed to work except it complained like in the video about LSB.
I decided to make sure I had this right so I used the script posted above and replaced my script with it. Since then I'm not getting VPN to autostart yet I can run the script manually so it's not a permission issue.
the reported issue I get is:
vpnserver.service - LSB vpnserver
loaded: loaded (/etc/init.d/vpnserver)
Active: failed (result: exit-code) since <date/time>
Process 859 ExecStart/etc/init.d/vpnserver start (code=exited, status=203/EXEC)
It seems like it is some kind of problem with the vpnserver script. If I manually run the thing and start it it works just fine.
Also after following all the steps very carefully when I try to connect from windows (local machine to the pi server so no router in place yet) I can connect the manager just fine. Connection windows VPN says connected, waits then says:
A connection to the remote computer could not be established. You might need to change the network settings for this connection.
Very strange. Guess I have some debugging to do...0
- 654 The Flea Market
- 385 SmartSDR API
- 51 Aurora
- 968 Maestro
- 940 Genius Products
