monitor temp on 6300
KB4HL
Is there still software add ons to monitor temp and voltage on the 6300 , I cant remember the website info. Thanks
Also, if all you want is voltage & temperature, I have written one:
http://http://www.k9dur.info/smartsdr_utilities.html
73, Ray, K9DUR
http://k9dur.info/smartsdr_utilities.html
Hi Ray
Your www. part isn't resolving. You'll need to add a pointer in your DNS records.
The above link works.
I thought you would like to know.
BTW, you and I agree on screen realestate. Small and Simple
73, Mike va3mw0 -
I believe ddUtil has it as well.0
Actually what happened was he put an extra http in the link. www does work.
Yes, it does.0
Thanks for the info
You can also use Flex Meter for temperature and voltage. The latest version also has a charting feature to show trends over time. It is at denzone.com1
With Flex Meter, to read the PA temperature, select TX for the meter source and PATEMP for the meter name. To read voltage, select RAD for the meter source and +13.8A for the meter name. More that one instance of Flex Meter can be opened at a time for metering multiple points.
That link looks OK but the hyperlink is bad. http//www.k9dur.info/smartsdr_utilities.html
(missing colon)
Try this. http://www.k9dur.info/smartsdr_utilities.html0
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
