FMT Upcoming Frequency Measurement Test (Thursday)
k3Tim
Member ✭✭✭
The 2016 FTM is this Thursday, April 7th at 0215 UTC.
I am debating some strategies for it and will likely use FLDiGi but wonder if a different program be better suited (Spectrum Lab)?
Since the FMT starts at 14.121Mc would there be any to correlate the propagation effects from WWV @ 15.000Mc ?
Thanks for any comments / guidance.
_..--
k3Tim
Tim, Sorry for the late reply but I use Spectran to measure the difference between my Flex6500 frequency and the signal being measured. My Flex is connected to a GPS clock so it is pretty much on frequency. I tune in the frequency to be measured in USB mode and then tune down 100 HZ. This creats a 100hz tone that I use spectran to measure very well down to .01 hz and this is the amount of error between my flex and the signal being checked. I also do this same test between wwv and my radio which normally indicates 0.02hz error. Don
Hi Don,
Thanks for this information and the setup - very helpful...
0.01 Hz resolution! Reading the old FMT scores, in the 70's they were lucky to be in the 10 Hz range, then technology progressed to within 1-Hz. Now we are at sub Hz range. It is interesting to see the effects of propagation in the measurement.
Unfortunately, I was unable to pickup the FMT signal. My end fed antenna is not the best.
Begards,
k3Tim
I've been contacted by a couple of people that needed some additional help with this. A common problem was getting PuTTY to do what they wanted connecting to the radio. The error in most cases was that they had launched PuTTY, entered the IP and port and attempted connection. Below the IP and Port is a protocol radio button that must be switched to Telnet rather than the default SSH.0
- 378 Community Topics
- 116 SmartSDR+
- 923 Genius Products
