Sound Card Does not See Mic Stream
Waht am I missing?
DAX is normally not used with the microphone. SmartSDR sees the microphone that is set in the default setting for your recording device in Windows. It is very confusing. I would like to see everything done manually and not automatically. Also, if you are using a computer microphone, be sure that "PC" is selected in the P/CW box.
Jim, K6QE
I kind of understand your answer. I am trying to make the N1MMLogger+ voice keyer work as well as the Writelog voice keyer. Both loggers say you can hit a series of keys and record on the fly. It all gets very confusing at the Windows 10 level. What is my recording device and what is my playback device? I think if I can get that figured out, the rest is pretty straight forward - more so with N1MM than with Writelog.0
Hi John
There are several threads on How To do these tasks, and may be some YouTubes as well.
http://bfy.tw/Bw4u is a link to a search on doing it with N1MM+ and http://www.flexradio.com/?s=n1mm%2B is the same on the FlexRadio Website.
Would guess a lot of what you want is in this one http://www.flexradio.com/downloads/using_n1mm_logger_with_smartsdr-pdf/
It is pretty easy to get this stuff in a whirl and I am hoping at some point the Community have a section dedicated to easy to use How To Guides.
Steve K9ZW
Steve,
Yes some help but the big problem is most of this is so far behind. It references very early versions of SmartSDR, there is no mention of the Maestro in any of this. And most of it is how to set things up for CW. CW setup is easy: what I need is help with the friggin' voice keyer!
Very, very frustrated with all of this right now.
John0
- 657 The Flea Market
- 438 SmartSDR for Mac
- 203 DAX
- 385 SmartSDR API
- 52 Aurora
- 296 FLEX-8000 Signature Series
- 969 Maestro
- 944 Genius Products
- 467 Remote Operation (SmartLink)
- 809 Peripherals & Station Integration
