CW Spot
Paul Christensen, W9AC
Would like to see a CW "Spot" feature added. Manual is good. Manual/Auto-Spot option is even better.
Manual operation would work like this:
While in CW mode, a right click and hold on the slice: (1) engages the sidetone; and (2) grabs the slice for movement in something like a predefined 10 Hz step. Releasing the right click button disengages the sidetone and releases the grab for the normal TNF function. In the alternative, a right-click engages the sidetone while also activating the mouse wheel for fine tune 10Hz steps.
Paul, W9AC
9
Exactly what we need Paul
I'd love to see this.. Tim NZ8J1
Paul,
Is this similar to the idea for AutoZeroBeat for Click tuning on CW?
https://community.flexradio.com/flexradio/topics/ssdr_autozerobeat_on_cw_click_tune
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
Al,
The automatic beat/spot function would be ideal for the long-term but even a manual tune function would be a welcome addition until then.
Paul, W9AC
Yes, a spot function to zero beat a CW signal would be a wonderful addition. I would no longer have to fine tune my receiver for the 400 hertz note that I prefer for CW signals.
John AK4Z0 -
Hi guys, please excuse my lack of understanding, but isn't that what the waterfall display is for? I just click on a signal, then I'm zerobeat. if I'm not, I see it and use the mouse wheel to adjust.
73 Frank
Hi Frank,
Depending on how accurately you click you may be close but not dead on. The AutoZeroBeat feature would do the fine tuning for you and lock on at zero beat. So just get close and let the software do the rest. It would be a feature you could turn on or off.
This "idea" is tied for the number 1 spot currently with 68 user votes.
Regards, Al / NN4ZZ
Frank,
Often, a click on the display doesn't net the frequency with enough accuracy, especially if the op on the other end is listing in a narrow, 50 Hz bandwidth.
Looks like this was raised three years ago. Hopefully, we'll see this and other convenience features starting to appear in SSDR 2.0.
Paul, W9AC
OK I understand that one, which makes perfect sense to me. The originally suggested solution with the sidetone not yet.
You are right, Frank, I do that myself. If I can hear a CW station in a narrow filter, say 200Hz,
I'm sure that he will also hear me if I transmit.
In ye olden times you had separate TX and RX (I loved that Drake line!) and you keyed the
CW sidetone without transmitting until the sidetone matched that of the received signal.
Then you switched to TX and you were sure that your signal matched that of the other
station if ... yes if that station did not run away while transmitting (no PLL locks at that time). Then you had to chase him, that was very funny and I liked it very much!
With modern TRX zero beating is only necessary if you follow other methods to tune
your CW signal, but - as I said - if you use the filter method there is no need for a spot
function anymore (Although I would like to try it, if only for the old times long ago :-))
http://www.qsl.net/v73ns/zerobeat.html
73, Alex - DH2ID0
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 62 Aurora
- 974 Maestro
- 950 Genius Products
- 348 Tuner Genius XL
- 128 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 145 Amateur Radio Interests
