Setting Max Power and TX Delay in Transmit Profile?
WA6HTP - Juan Rivera
How do I set individual profiles with different maximum power and TX delay settings? I want one profile when running barefoot and another when using the amp so I can limit maximum power and not overdrive the amp by accident. The TX delay is needed to prevent hot switching the amp. I'm using SrmartSDR v1.10.15.43.
Transmit profiles will save the settings your asking about. Save the required settings in two different TRANSMIT profiles.
Tx power and Tx delay are saved in a TX profile. Set up the Power levels per band and the TX delay once and save a TX profile to a new name... Select the desired profile in the TX panel in SSDR.
AL, K0VM
- 654 The Flea Market
- 385 SmartSDR API
- 52 Aurora
- 968 Maestro
- 940 Genius Products
