wnb creates noise on 6m
G8ZPX
On a very quiet 6m band I was chasing a noise source (see pic), trying to find what was producing the odd repeating vertical bars in the panafall.
After a while it turns out it was actually being caused by the WNB function...the band was pure white noise (without a glitch) when the WNB is turned off.
However, even when the WNB slider is set to zero it still does it. Only by turning WNB off completely makes the lines disappear. The break in the lines shows where I turned the WNB off/on to demonstrate the difference.
I do not experience this on my 6700.
I would recommend exporting profiles and performing a total reset on the radio. I do this every single time I do a software upgrade now. It prevents some of the strange behaviour I've sometimes experienced in the past.0 -
First thing I tried. Makes no difference.
Also, the RX antenna selection makes no difference either. Even when on RXA or XTVR (I have nothing connected to them) the self-generated noise is still there.
You wouldn't happen to have LOOP A or B selected would you?
I experience this but only with certain band conditions, meaning strong signals on the band.0
I have entered this problem report into our bug tracker as issue #4668 for additional investigation. Thank you for the defect report.
- 331 Community Topics
- 598 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 398 SmartSDR for Mac
- 261 SmartSDR for iOS
- 247 SmartSDR CAT
- 180 DAX
- 369 SmartSDR API
- 9.1K Radios and Accessories
- 15 Aurora
- 164 FLEX-8000 Signature Series
- 911 Maestro
- 51 FlexControl
- 873 Genius Products
- 312 Tuner Genius XL
- 115 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 135 Contesting
- 726 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 947 Third-Party Software
