How to select RCA TX2 for XVTR Keying, and avoid keing in other HF band.
William Schauff
Hi All!
I would like to have RCA TX2 keying my XVTR, only when in use. If I TX in  any other HF band , XVTR is also activated  and there is a big mess.
Please inform how to select exclusive keing of TX1 TX2 TX3 acording to the band in use.
TNX
William - PY2GN
  • EA4GLI
    EA4GLI Member ✭✭✭
    edited April 2017
    As far as I know it cannot be done. I have been asking for this feature for over a year.
    At the very least I would like direct access buttons in the GUI for the TX, instead of having to go through menus to get to them to find out even if they are on or off. Similar to the way you can enable/disable FDX and you can see right away if it is on.
    Working with an amp, a 144 amp and a 440 transverter will be easier if this feature was enabled.
  • David Livingston
    David Livingston Member ✭✭
    edited April 2018
    I would like o see this also....
  • Ken - NM9P
    Ken - NM9P Member ✭✭✭
    edited June 2020
    Can this be done via the new USB port utility? Perhaps using a bit cable.?
  • Larry _ NY8T
    Larry _ NY8T Member ✭✭✭
    edited July 2018
    Create a transmit profile for each band with only the needed tx rca activated in each one.
    transmit profiles are discussed at the 8:30 mark
    https://www.youtube.com/watch?v=xAdz1GRbg9Y&t=5s
