How to select RCA TX2 for XVTR Keying, and avoid keing in other HF band.
William Schauff
Hi All!
I would like to have RCA TX2 keying my XVTR, only when in use. If I TX in any other HF band , XVTR is also activated and there is a big mess.
Please inform how to select exclusive keing of TX1 TX2 TX3 acording to the band in use.
TNX
William - PY2GN
TNX
William - PY2GN
2
As far as I know it cannot be done. I have been asking for this feature for over a year.
At the very least I would like direct access buttons in the GUI for the TX, instead of having to go through menus to get to them to find out even if they are on or off. Similar to the way you can enable/disable FDX and you can see right away if it is on.
Working with an amp, a 144 amp and a 440 transverter will be easier if this feature was enabled.1 -
I would like o see this also....
Can this be done via the new USB port utility? Perhaps using a bit cable.?0
Create a transmit profile for each band with only the needed tx rca activated in each one.
transmit profiles are discussed at the 8:30 mark
https://www.youtube.com/watch?v=xAdz1GRbg9Y&t=5s
- 244 Community Topics
- 481 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 162 DAX
- 348 SmartSDR API
- 8.5K Radios and Accessories
- 747 Maestro
- 41 FlexControl
- 722 Genius Products
- 250 Tuner Genius XL
- 84 Antenna Genius
- 225 Shack Infrastructure
- 150 Networking
- 120 Contesting
- 114 Amateur Radio Interests
- 805 Third-Party Software
