no rf or swr indications when transmitting
edited December 2019 in FLEX-6000 Signature Series
I'm having a weird condition where when keying a mic attached to the front of the 6500 and Smart SDR V1.10.16, I don't show any RF power or an SWR. The panadapter does show my voice.
I unkey and then rekey and everything is fine. This has happened at least twice in the last two weeks and I can't seem to replicate the scenario. Has anyone seen this? Is there something else I should check for to help diagnose?  I don't have an external wattmeter to place inline.
Welcome!
  • Member ✭✭
    edited April 2017
    Perhaps this problem could be better resolved by trying this scenario into a dummy load. RF will bite you in the **** when ever it can.
    Jim, Ky6QE
  • Member ✭✭
    edited July 2017
    Well I suppose, but I find that it is a bit harder to make contacts using a dummy load.
  • Member ✭✭✭
    edited November 2019
    What's your antenna output selected for tx?
  • Member ✭✭
    I've seen and reported this problem several times to the Alpha test group. I'm almost certain that this problem is in the software defect tracker.
  • Member ✭✭✭✭
    edited July 2019
    I've had the same thing happen, but it's very intermittent (like it happened once today while working the Rookie Roundup) and it seems to go away just as quickly.  LIke on the next transmission.  However, in my case, I obviously go into transmit mode, but there is no indication on the panadapter, no RF output, no SWR indication, no compression or audio indications either.  It's like the PTT has been activated and I'm in TX mode, but everything else still thinks it's in RX mode.
  • Member
    edited January 2019
    I've seen the same as well,  Has not showed up over the last few weeks as I am now running the latest release.  Been intermittent is does make it very difficult to track down.
  • Member ✭✭
    edited April 2017
    Ant 1
  • Member ✭✭
    edited July 2019
    Has anyone been able to determine if the radio is in fact transmitting and it is just a display glitch? I'll try to catch it in this state and see if the front panel power indicator shows green or red, and if possible take a video.
  • Member ✭✭
    edited July 2017
    I went ahead and opened a support ticket since I don't seem to be the only one encountering this.
  • Member ✭✭✭✭
    edited April 2017
    As far as I've been able to determine, in my case the radio is NOT transmitting when I see the fault.
  • Member ✭✭
    edited April 2017
    I have on a couple occasions!
  • Member ✭✭
    edited May 2019
    I'm setting up my new (Flex reburbed) 6500 and have the same problem.  Key the mike and there is an energy spike on the panadapter, but zero activity on the RF Power or SWR sliders.  I talked with Flex at the Yuma HamFest and they said to be sure I had the right microphone selected.  I didn't.  Do now.  Makes no difference.
    Did anyone get this fixed?
  • Member ✭✭✭
    edited February 2018
    re check all the settings in TX under radio settings, TX inhibit?
  • edited February 2018
    Power level, mic gain etc. all effect this as well.
  • Administrator, FlexRadio Employee admin
    I recommend updating to the latest version of SmartSDR v1 (1.11.12) and see if the problem still exists.
  • Member ✭✭
    edited May 2019
    In my case it is the Tone switch on the included FHM-1 microphone.  Setting 1 transmits.  Setting 2 is dead.
