What is SCU-A RX Loop Output used for?
I have hooked a loop antenna to the SCU-A RF Input.  I was wondering if SCU-A RX Loop output can be used to feed another receiver?  What is te purpose of SCU-A RX Loop output?
Love the ability to simultaneously receive on one antenna while I am transmitting on another.  It is extremely useful.
  • Ken - NM9P
    Ken - NM9P Member ✭✭✭
    edited June 2020
    It is like and effects loop in a PA.... You can loop your antenna out to a preamp, bandpass, or notch filter,  then back into the RXA input.  That way the filter is always out of the TX power amp line and safe from damage.
    If you don't use the Loop, then you can simply connect a receive only antenna to the RXA input.
  • Ria
    Ria Member ✭✭✭
    edited April 2017
    So will this do feedback for adaptive predistortion? That was my guess.
  • Jim - wa6our
    Jim - wa6our Member
    edited April 2017
    Ahh.  Got it.  Guess it won't do what I want to do, oh well.
    Like the idea able to receive while transmitting.  Very useful.
    Thanks for you explanation.
  • George KF2T
    George KF2T Member ✭✭✭
    edited February 2019
    The full-duplex mode allows transmitting and receiving simultaneously. Check the manual for the details. I use it frequently for satellite work.
