FLex Radio 6300 with Microham MK2 for AFSK mode
Felice, IZ8FFA
I have a MicroHam MK2 and she run very well in my Flex 6300 in the Phone and CW mode but don’t have succeed to setup for the AFSK mode. Please, anyone use this machine and can help me? Thank you.
What does not work when doing AFSK ? Is PTT working ?
Andy K3UK0 -
Hi Andy and tNX for reply. Yes, the PTT work but don't have the sound
Hi Felice
I'm not sure what your AFSK mode problem is & I'm afraid I don't understand why you are using a MicroHam MK2?
You don't need an interface like the MicroHam with the Flex 6000 series radios as I do AFSK RTTY using the Flex RTTY mode & I do PSK using the Flex DIGU mode, both using software like MMVARI or MMTTY or FLGIGI etc
Ray G3XLG
Hi Ray, I want to use the interface becouse don't like to go with the mouse in some window as FLDIGI or similiary, . With the MK2 I push 1 key and go!
Ray, check MicroHam site, check MK2R and what function this device has. Then you will remove you comment:
- I don't understand why you are using a MicroHam MK2?
- You don't need an interface like the MicroHam
How do you operate SO2R mode, how do you manage PTT of 2 radio (only one TRX at any time), how do you manage audio output of 2 TRX on your headphone
... and the MK2 work also in SSB, CW, ....
73 Chris0 -
Chris, ..... Felice asked about setting up AFSK .
He did not ask about SO2R nor about the MK2R!
I stand by my comments, you do not need to use the MK2 to generate AFSK using a Flex 6000 series rig.
By the way I do own & use an MK2 with my K3 as an interface for digital modes but I do not do SO2R
73 Ray G3XLG
- 109 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
