How well will the new 9.7 2017 iPad work with the SmartSDR IOS
Dennis Daniel KM6DF
Extremely Well0
Almost as good as the iPad Pro 9.7 which is pretty darn good.0
Mine works fine with just an iPad Air. So that one should be even better.0
Thank you all I have a generation 4 now it works but it is very choppy. I don't want to buy a new iPad and have the same issue0
I just switched from the Air to the new 2017 model (my Air was running out of room.) Running OpenVPN Connect and SmartSDR for IOS just fine.0
Works great with iPad Pro, I'v been working DX on 40 meters during the evening from my family room using AirPods for the receiver and mike.0
Well I got the new iPad and works fine but still choppy . Setup is an asus router and iPad running open vpn any ideas0
You didn't mention how you are connecting. I assume remotely via VPN from your comment. Are you connected via cellular network or WiFi? Try going to speedtest.net and check the ping and upload/download speed. Make sure your home network and remote network are not using the same subnet scheme (192.168.1.x for example). I set my home network for 10.6.0.x with 6700 set for a static IP on network. My rempte 6500 subnet is 10.7.0.x with the 6500 set for sratic on that network. Which Asus router? For home LAN i've found faster speed with IOS devices (new iPad, iPad Air 2 and iPhone 7Plus) by disabling explicit and universay beamforming for both the 2.4 and 5 GHz channels. If running over remote WiFi network make sure that network isn't set for multiple routers on same WiFi channel ( and apartment building for example). Last, try a cold boot of the iPad to ensure nothing else is running. I've found one app that does not run correctly on IOS 10. To do a cold boot Press and hold the Home and Power Button until your iPhone / iPad reboot (ignore the "Slide to turn off"), you can release both buttons when you see Apple logo. I'm running the new 32 gig WiFi model with no issues when running SmartSDR for IOS. Dave wo2x0
Thanks Dave I have a rt - ac68p router my connection is cat 6 to my 6500. The asus router is setup for vpn and the iPad is a the new 2017 iPad running open vpn0
- 369 Community Topics
- 628 The Flea Market
- 82 SmartSDR+
- 422 SmartSDR for Mac
- 270 SmartSDR for iOS
- 189 DAX
- 34 Aurora
- 243 FLEX-8000 Signature Series
- 937 Maestro
- 54 FlexControl
- 915 Genius Products
- 332 Tuner Genius XL
- 450 Remote Operation (SmartLink)
- 779 Peripherals & Station Integration
- 995 Third-Party Software
