DDUtil Auto-Load macro file
But how can I get DDUtil to automatically load my list of macros and link them to the macro buttons without needing to manually "Load" them every time I start up DDUtil? I have looked in the online help, but I meed to have missed it.
Hi, would someone please share there 6500 macros as well. I have been running DDUtil for a couple of years and discovered the macros watching a youtube video.
Mike0 -
Found it, finally! Under DDUtil Setup > Files, Macro Data File under F6000, enter the file name I have been saving my Macros. Don't know how I missed it, right under my nose..... or mouse!0
Ken,
Assuming you have saved the macros under Setup>macros, go to Setup>Files and add your Macros Data File just saved to the F6000 box.
And when you done with that you should also Options>Backup user settings..
AL, K0VM0 -
DDUtil saves the macro file name in the user settings file. If you have added some macros to the grid on the Macro tab and then saved them to a specific file name they should be recalled when DDUtil next starts. Using the Macros function is fully defined here.
If this is not happening then the user settings file may be corrupt and needs to be reset per this wiki article.0 -
Mike, Here are a few I have been running....
RX 1
DD6RXA0:0;DD6PRG0:0;RX 2
DD6RXA0:1;DD6PRG0:0;
RX RXA
DD6RXA0:2;DD6PRG0:20;
TGL RX ANT
DDTG01:003:001:10;
(Toggles between the RX1 and RX RXA macros to set receive on RXA and add 20 dB gain)
Preamp 0
DD6PRG0:0;
Preamp 10
DD6PRG0:10;
Preamp 20
DD6PRG0:20;
CWA Enhance
DD6SSF0:-0000:00050;DD6AGM0:0;DD6APF0:1;DD6APG0:030;DD6NRD0:1;DD6NRG0:010;
Pan1 5K Zoom
DD6PBW0:.005;
Pan 1 10 KHz
DD6PBW0:.010;
Pan1 150 KHz
DD6PBW0:.150;
CWB Enhance
DD6SSF1:+0000:00050;DD6AGM1:0;DD6APF1:1;DD6APG1:030;DD6NRD1:1;DD6NRG1:010;
Pan 2 5K Zoom
DD6PBW1:.005;
Pan 2 10 KHz
DD6PBW1:.010;
Pan 2 150 KHz
DD6PBW1:.150;
MIC DX 2.3
DD6PMC:PR22-DX-2_3K NAR;
(Calls my Mic Profiles by name – edit for your own profiles. Only recognizes UPPER CASE names)
MIC DX 2.7
DD6PMC:PR22-DX-2_7K;
MIC Rag
DD6PMC:PR22-RAG;
MIC 6K ESSB
DD6PMC:PR22-WIDE 6 K ESSB;
CW 250 Hz
DD6SSF0:+0000:00250;
AGC FAST
DD6AGM0:0;
AGC MED
DD6AGM0:1;
AGC SLOW
DD6AGM0:2;
AGC OFF
DD6AGM0:3;
The whole list of available macros is accessible via DDUtil's Help>Macro Reference tab.
It will open up a browser link to the latest macro help file.
Hope this helps,
Ken - NM9P
Hello, finally got around to set up macros. Works great!! Thank you,Mike.
- 379 Community Topics
- 631 The Flea Market
- 123 SmartSDR+
- 193 DAX
- 39 Aurora
- 948 Maestro
- 925 Genius Products
- 337 Tuner Genius XL
