Mic profile associated with slice and mode
Bill W2PKY
Currently the mic profile is associated with the mode and is globally applied to all slices. The issue I have is with DIGU and 60M where the audio bandwidth is limited to 3kc . All other bands are unlimited. So if band hopping on a Mic profile of 0-4000 high cut, when selecting 60M the trainsmit icons are grayed out. Perhaps SSDR could simply reduce the high cut to 3kc ?
Just Reset Your Hi Cut To 2/9 Or 3/0 And It will Key Right Up On 60 Meters0
2.9k. The channels are not 3k wide in the US.0
I would like the 60M slice to automatically set the parameters appropriately when the TX icon becomes active and then when the other slice TX icons are active the Mic profile values are restored. When band hopping [with less than 10 seconds between decoding and transmitting] there is not enough time to manipulate these values manually.0
An additional thought on this subject : Would be nice if the low and high cut parameters behavior were just like the power slider. Thiat is, with each selection of a transmit "TX" ICON the values could be modified and SSDR would remember the values when returning to each slice.0
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
