API: Persistence load change for clients that identify as GUI
With the remote WAN feature there is going to be a slight API change regarding GUI clients and persistence loads. (If your 3rd party client does not set the API.IsGUI variable OR you never send the 'client gui' command this will not affect you).
Currently:
When a client sends a command to the radio that sets the UDP port, persistence is loaded if the client is the GUI client. All previously persisted panadapters are loaded along with their corresponding slices. If a GUI client does not want persistence to load it must issue the command 'client start_persistence off' *prior* to the 'client udpport <port>' command.
Planned Changes:
Persistence will now be loaded when the 'client gui' command is issued and *not* when the UDP port is set. This should have no impact on clients *unless* the client depends on not loading persistence. If a GUI client does not want persistence to load it must issue the command 'client start_persistence off' *prior* to the 'client gui' command.
This change will be compatible with previous versions of radio firmware so updated applications will still work with older versions of SmartSDR.
Questions? Thoughts?
Currently:
Planned Changes:
Thanks for the heads-up Ed.0
- 395 Community Topics
- 674 The Flea Market
- 187 SmartSDR+
- 192 SmartSDR for Maestro and M models
- 454 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 87 Aurora
- 325 FLEX-8000 Signature Series
- 984 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 313 Shack Infrastructure
- 218 Networking
- 836 Peripherals & Station Integration
- 146 Amateur Radio Interests
