Need Urgent Help n1MM voice Setup
Mike NN9DD
Need a document on how to set up N1MM Plus with SMART SDR for voice keying. Chris Tate had this working and had a document but I cant find it and we are less then an hour
Help
There is a bit of a writeup on N1MM voice keying here: https://community.flexradio.com/flexradio/topics/the-new-voice-keyer-works
DAX is your friend. Once you set up your DAX TX you should be able to use that device as you would use a sound card in N1MM+.
See page 6 of this, and the 2nd to last page where it discusses N1MM+ logger audio
http://www.flexradio.com/downloads/so2r-mode-with-n1mm-for-the-flex-6700-how-to-guide-pdf/
Thank all0
- 390 Community Topics
- 659 The Flea Market
- 53 Aurora
- 971 Maestro
- 945 Genius Products
- 307 Shack Infrastructure
