remote_audio rx_on 1 - reply
Doug - K3TZR
I have a client connected to my Flex-6500 as a "gui" client.
When sending "remote_audio rx_on 1" the Radio responds by starting an Opus stream but the command reply is "50001000" which seems to indicate a problem. I would have expected a "0" reply indicating no problem.
I've used Wireshark to verify that the same response is being sent to SmartSdr when the Remote button is selected.
The "remote_audio rx_on 0" command also receives a "50001000" reply but seems to work correctly.
Doug,
Thanks for bringing this to our attention. I have added #4583 in our bug tracking system to address this. As you noted, I don't think there is any harm in using the function as it looks like it is just the reply that is incorrect.0 -
Thanks Eric,
you are correct, it doesn't seem to stop anything from working. I just thought I was doing something wrong. When I noticed it happening with SmartSDR, I decided I should ask.0
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
