Flex 3000 Waterfall Disappeared
Ron Miles
PowerSDR v2.7.2, Waterfall quit working today. I've had this problem before where I could reset the waterfall by rebooting my PC and F3K as well as disconnecting power between the F3K and power source. These solutions no longer work. Looking for other remedies that would bring my waterfall back to life. Help greatly appreciated. Ron n6paa.
hi Ron. i also run a f3k and had similar problems when using psdr 2.7. my band block use to dissappear or my power button onscreen wouldnt illuminate. weird little things , but annoying. i upgraded to the KE9NS version of psdr many months ago and it runs trouble free now with a few extra added features that the standard Psdr doesnt have. once you use Darrins version you wont go back. look at google. search KE9NS flex and have a read. worth the install. Follow prompts carefully and delete what is suggested. its actually a "self installer zip" these days..but you may have to drop 2.7.2 off your system first. check out the read me stuff b4 doing anything. good luck. marty vk2vcc0
I agree with Marty. It worked for me quite well. I had issues getting the VSP working with Power SDR. As the installation notes say, you can still have your Power SDR in the system, without impacting on the installation. Hope it fixes the issue for you
Sasi
VK5SN
Ron,
If rebooting the computer does not correct the issue , then re-run the PowerSDR installer.. This should correct the issue.0 -
Thanks all for quick reply. I'll try the PowerSDR installer. The KE9NS flex app looks interesting, might try it. Thanks, Ron n6paa0
you wont regret it Ron. ke9ns version is awesome. 731
This didnt work for me..
It did not work for me.
Did this also and it did not fix it ?
- 383 Community Topics
- 638 The Flea Market
- 145 SmartSDR+
- 434 SmartSDR for Mac
- 273 SmartSDR for iOS
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
