PowerSDR.xml fldigi s-meter
Steve Radoff
Does an updated PowerSDR.xml file exist that provides s-meter data from FLEX5000a to fldigi? Or is there xml code for accomplishing this?
check out woodbox radio. I use one of theirs on my flex1500 with pwrsdr.
Keith W7zac
No. Fldigi's RigCAT interface does not have accommodations for S-meter readings.0
Fldigi that I run (3.22) has an s-meter on its panel. Fldigi has a protocol for the s-meter. PowerSDR has a CAT protocol for its s-meter. CAT is connected between fldigi and PowerSDR. Is there no way to define an s-meter connection in PowerSDR.xml?0
I stand corrected. It does look like newer versions of RigCAT do allow for polling S-meter and power meter data, so it looks like it could be added to the xml file.0
Upon a little more investigation, the S-meter / Power-meter displays are only active if Fldigi is configured for xmlrpc control with Flrig. As per the Flrig documentation, none of the FLEX SDRs are currently supported.0
- 363 Community Topics
- 624 The Flea Market
- 8.1K Software
- 69 SmartSDR+
- 420 SmartSDR for Mac
- 270 SmartSDR for iOS
- 253 SmartSDR CAT
- 188 DAX
- 379 SmartSDR API
- 30 Aurora
- 233 FLEX-8000 Signature Series
- 933 Maestro
- 909 Genius Products
- 329 Tuner Genius XL
- 120 Antenna Genius
- 291 Shack Infrastructure
- 204 Networking
- 447 Remote Operation (SmartLink)
- 771 Peripherals & Station Integration
- 989 Third-Party Software
