PowerSDR.xml fldigi s-meter
Steve Radoff
Does an updated PowerSDR.xml file exist that provides s-meter data from FLEX5000a to fldigi? Or is there xml code for accomplishing this?
check out woodbox radio. I use one of theirs on my flex1500 with pwrsdr.
Keith W7zac
No. Fldigi's RigCAT interface does not have accommodations for S-meter readings.0
Fldigi that I run (3.22) has an s-meter on its panel. Fldigi has a protocol for the s-meter. PowerSDR has a CAT protocol for its s-meter. CAT is connected between fldigi and PowerSDR. Is there no way to define an s-meter connection in PowerSDR.xml?0
I stand corrected. It does look like newer versions of RigCAT do allow for polling S-meter and power meter data, so it looks like it could be added to the xml file.0
Upon a little more investigation, the S-meter / Power-meter displays are only active if Fldigi is configured for xmlrpc control with Flrig. As per the Flrig documentation, none of the FLEX SDRs are currently supported.0
- 388 Community Topics
- 156 SmartSDR+
- 53 Aurora
- 970 Maestro
- 944 Genius Products
