cwx operation could be improved
Bruce Elbert
CWX for Smart SDR works pretty well as you type and the buffer empties. The code is consistent and smooth. However, I have two issues: (1) the backspace removes the characters on the screen but they are transmitted anyway, and (2) the audio I hear is advanced in time from what is transmitted. On item (2), it is disheartening that I have to wait extra time after the sound of the characters finishes.
I have an issue regarding remote CW, which works well using the VPN to my home router (an ASSUS). I'd like to use my keyer and PC to send code, but the audio isn't there. I suspect I need some kind of audio transfer through the pc which is not otherwise provided.
Thanks. 73, Bruce K6ZB
What version of SmartSDR are you using?
Tim it's version 1.10.15. 73, Bruce K6ZB0
Please upgrade to the general release of 1.10 (1.10.16) and see if you are still having the same issue as you reported for item #1.
Regarding #2, that is a normal consequence of an SDR, as there is latency between the time the tone is generated and RF is transmitted. It is a matter of physics; the time it takes for a signal to propagate through the DSP logic.0 -
Tim, I just tried back spacing in 1.10.16. Again, it erased from the screen but sent the characters anyway. This should be easy to verify on your end. Thanks. Bruce K6ZB0
This issue is in our bug tracker as defect #4542. I have added your comments to it.0
Tim, thank you. You can't believe how helpful this will be. I CWX is otherwise the best solution for remote CW. 73, Bruce K6ZB0
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
