ipad 4 does not discover Griffin PowerMate Bluetooth controller
Bob KN4HH
Member ✭✭✭
I just received a Griffin PowerMate Bluetooth Controller and attempted to mate it with my iPad 4 for use with SmartSDR ios. The iPad does not see the controller. Other Bluetooth devices (speaker, headset) are discovered by the ipad with no problem. The controller is discovered by all of my Android devices. I am a casual ipad user so I suspect I am missing something fundamental. I would appreciate any assistance.
73, Bob, KN4HH
73, Bob, KN4HH
Hi Bob,
thanks for your post.
How did you find out that your iPad does not see the controller ?
Maybe you expect it to appear in the Bluetooth list in the Settings of the iPad, right ?
But for Bluetooth LE devices, that's not necessarily the case. Bluetooth LE works completely different to Bluetooth. Bluetooth and Bluetooth LE have not much in common other than the name. I also found it very unfortunate that Bluetooth LE is called "Bluetooth" as well - which causes many confusion and expectations.
However, if that's the case and that's the reason why you think your Griffin doesn't connect to your iPad, don't worry. Just follow the procedure described in the manual (go-to.me/smartsdr-tools-manual) and you should be set.
Please let us know about your progress.
vy 73,
Marcus, DL8MRE0 -
Marcus, you were right. I was looking for the Griffin in the mating list. Once I configured it according to the manual, it works fine. Thanks so much for getting me straightened out. Thank you for a great application.
73, Bob, KN4HH
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
