Virtual Comm Port Software That Works with SmartCAT & Windows
Tnx
Rick, W2JAZ
i run a flex3k and had similar issues. i now run a combination of VSPmanager and VSPE with no issues. this combined with Log4OM and fldigi , wsjt and option of another 2 ext programs if i wish. i found running vspmanager on its own couldnt handle the traffic. Vspe was required to create a split port and it works but yes its virtual creations are hidden in the background. vspmanager places port emulation within windows always. another thing to watch is the baud rates .i run max of 57600 . i have read other guys here use 114000 !! when you say yours trips you up , can you give me a better example of your use. cheers. ps i have spent many hrs on this stuff, and mine seems stable atm. i do have a diagram of my setup somewhere (xls file).i will try and find it or dropbox it.0
But are you running SmartCAT at the same time as the other virtual serial apps?0
Rick
vspManager , and SmartCAT, are co-existing fine, on my Win10 box.
You do have to be careful when creating the ports, that either vspM or SmartCAT don't ever assign any ports used by the other. And also you need to watch out for any ghost ports and remove them in Dev Manager. The two apps can't see the port assignments the other app makes, and will often try to assign port numbers the other has already assigned. When removing Virtual port always first try to use the app that created them.
My guess is, anyone trying to run both a Legacy Flexradio, and a 6xxx series Flexradio,from the same PC has had to figure this out, so that both PowerSDR and SmartSDR will have Com Ports to use with digital apps.And vspManager is also the only option for creating shared ports, that will probably be needed. SmartCAT no longer has that ability.
73, Jay - NO5J
im sure you could using Vspe with a splitter port0
But I wonder if they would coexist in a windows 7 environment which is what I have. I've run VSPManager before and I seem to recall I had the same issue, but maybe not. I know that VSP Manager ports do actually show up in Device Manager which probably means they are Windows signed. I hate to do it but maybe I should upgrade to Win 10. Too bad I missed the free window!
Rick0 -
zoom in on this xls.. it may give you insight to fix port issues. do you have a direct email? my xls file will not send here.0
rjlawn at gmail dot com0
Rick
It should work on Win7 too, I used to do the same on win7 before win10. Win10 so far has worked flawlessly for me but I keep an eye on it for trouble. I've seen things I never saw when using Win7.73, Jay - NO5J
- 378 Community Topics
- 118 SmartSDR+
- 192 DAX
- 38 Aurora
- 947 Maestro
- 924 Genius Products
