Maestro - Dell venue 8
Steve G1XOW
Steve G1XOW Member ✭✭
Will the Maestro app run on a Dell Venue 8 tablet?   I know this is the heart of the Maestro box, but does it actually need the knobs and sliders to run and be usable?   I have installed the full SSDR already, but just considering options.
73 de Steve G1XOW
  • Mike va3mw
    Mike va3mw Member ✭✭
    edited February 2018
    Steve Why not just run SmartSDR on the tablet. Would that work? (Sorry, I don't know what operating system the Tablets run). Mike
  • Ria
    Ria Member ✭✭✭
    edited November 2019
    It should run on a windows 7, 8 or 10 tablet. The only issue I see is the text being too small.
  • Ria
    Ria Member ✭✭✭
    Btw https://community.flexradio.com/flexradio/topics/has_anyone_tried_smartsdr_on_the_dell_venue_8_pro As long as it is WINDOWS and not android it should be fine. You won't have any knobs but that doesn't seem important to you.
  • Tim - W4TME
    edited June 2020
    The answer is no because the Maestro application is not available to be installed on any other device and if it was, it will error out when it cannot find the Maestro hardware to initialize.
  • Steve G1XOW
    edited February 2017
    Thanks Tim. That is what I expected, just wanted to check first.
    I'm sure the spec is fine to run SSDR on the Venue 8 (2gb, W10, quadcore). But I suspect trying to use the full SSDR on it (W10 at 1280x800 resolution) will be too small and impractical for some of the the tiny controls/sliders. Will also try scaling options and report back.
    73 de Steve G1XOW
  • Paul Christensen, W9AC
    Paul Christensen, W9AC Member ✭✭
    I'm using a Dell Venu 8 Pro tablet running SmartSDR and Win 10.  Works fine.
  • Ken - NM9P
    Ken - NM9P Member ✭✭✭
    If you want to run something other than SSDR for Windows on a tablet, and have an iPad or even an iPhone, try SSDR for IOS.  It is awesome!  K6TU's Remote app is also a great piece of software.
