Does DDUtil talk directly to the Flex 6500 using API's or does it communicate thru the CAT System?
Tom K3TF
Still learning all the software pieces. I found that I can run DDUtil and read Flex 6500 Temperature and Voltage, and other parameters, with out loading CAT when I installed the latest version of SDRSmart vs 1.10.16. My guess is that I can add a second FlexControl running under DDUtil and control the Flex 6500 with out having to load the CAT drivers.
Does this make sense?
Tnx,
Tom.......
K3TF
Tnx,
Tom.......
K3TF
DDUtil uses the FlexLib API and it also uses SSDR Cat (TCP/IP port) at times depending on what commands/macros are being executed from DDUtil. So yes, Cat needs to be running.
I suggest DDUtil questions be sent to the DDUtil Yahoo group and not the Flex Community as I don't always monitor here.0 -
Steve,
Thanks for the info.
Tom
K3TF.........
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
