API Changes: Meter Scale and Transmit property of Slice class
Eric-KE5DTO
Administrator, FlexRadio Employee admin
We have made some changes to our API recently that developers may be interested in.
First, we changed the divider for the Voltage type of Meter from 256 to 1024 to give us room for higher voltages that we are monitoring in the Power Genius amplifier. This change in the ethernet API is handled transparently in FlexLib and will be included in the next public release beyond v1.10.16.
Second, based on feedback from multiple developers, the Transmit property in the Slice class (FlexLib) has been renamed to IsTransmitSlice. This should help resolve the confusion when some developers would set this property to true and expect the radio to be transmitting when it was simply designating a particular Slice as the Transmit Slice (as the new name reflects). This change only affects the FlexLib API (not the ethernet API). This change will also be included in the next public release following v1.10.16.
Hi Eric,
Thanks for the heads-up.
Surely the voltage divisor change must be from 1024 to 256 rather than the other way round?
Will the API protocol version number, currently 1.2.0.0, be changed when these changes are implemented? This seems to be a safer way for Ethernet API software to unambiguously determine which scale value to use.
73, John
You are correct. The divisor goes from 1024 to 256.
We did indeed bump the API protocol version to v1.3.0.0.0 -
Thanks Eric. My API library code is ready for ya!
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
