WSJT-X Unable to transmit
W9TVX
I have WSJT-X 1.7 configured to connect and work with SmartSDR 1.10.15 and a 6700
When WSJT-X goes in to transmit mode:
Some smart SDR info: Mode is DIGU (I also tried USB), Passband 3K
Note I can transmit no problem using my PR-781
I have rebooted both computer and radio multiple time
Any help appreciated
Ross
w9tvx
- 6700 keys up (green LED goes red)
- DAX Control Panel TX button is Blue and the meter is showing audio present
- SmartSDR P/CW panel shows the correct level i.e. right carat just below 0 and audio on the level meter, DAX button blue
- If I turn on monitor I can hear the JT65 tones
Ross
w9tvx
Do you Check This?
Check the Low and High Cut settings, should be 0-40000
That was it, and it makes perfect sense! I was fixated on the pass band envelope under RX and failed to see the TX low cut and high cut.
Thank you!
Ross
w9tvx0 -
You may have to setup a PTT in CAT. I don't know your total setup...0
This is where the 'fake-it' split setting in wsjt-x is useful as on transmit it automatically moves frequency so that the transmitted tones are around 1.5khz, well within the usual TX passband.1
There is a defect registered on the code for occasional drop-outs similar to what you are reporting. This may not explain what you are seeing, but if it does, it's on the list to investigate and deal with.
Flex 6500..Same issue here still unable to get power output. Works fine on JT65, no issues
Any other suggestions?
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
