USB CAT
Paul M
Paul M Member ✭✭
After a few unforced errors as well as bothering Dudley and a few others, I was able to get the SPE 2K-FA connected to the 6500.  It is the first time that have implemented the automatic power set by band.   Was great combination the Flex and SPE are together.   Thanks to the Flex development team.
  • Ian1
    Ian1 Member ✭✭
    edited May 2020
    While I am glad you got it working I see no advantage to this direct connect method other then field use and no computer just using Mistro.
    Ian
  • Steve WS5W
    Steve WS5W Member ✭✭
    edited April 2020
    Do you have a write up or a checklist that you used?
  • Chris DL5NAM
    Chris DL5NAM Member ✭✭✭
    edited April 2020
    Ian, for remote operation is it also important.
  • Ria
    Ria Member ✭✭✭
    edited February 2017
    It allows you to eliminate ddutil which I don't always want to use. Plus it allows you to set cat frequency by antenna output rather than by slice.
  • Ian1
    Ian1 Member ✭✭
    edited May 2020
    I get what it allows you to do Flex contest Rep showed me. If I was a Maestro user it would be great but I'm not. I do remote on occasion which works with Team Viewer or other remote programs.
    DDutil I find is a very nice helper program and am satisfied with it's performance.
    It allows me to Power my SPE Amp and various preprogramed Antenna and power outputs conditions also allows the HF Auto to tune control my rotor etc.
    BTW I also spoke at length to SPE Rep that makes cables for the direct input.
    Ian
