Yet another KAT500 /KPA500 question..
Hi Chris. The odd thing is, using the KXUSB, I can see from the USB logger in SSDR that the band changes are being reported...but the KAT500 doesn't change (maybe indicating that the KAT500 isn't seeing the bandchanges. However, using DDUtil the KAT500 bandchanges just fine...using the same cable and KAT500 connection but plugged in tp PC instead of 6500... can't work it out...0
I have to say that I'm not the biggest fan in the world of the KAT500. 80/40/20/15/10/6 are all resonant at my QTH. 30/17/12 are used with the tuner on the 80 meter loop. The tuner gets "spikey" on me - it'll find a match just fine, then in the middle of transmitting, something will spike, and it'll go through a search again to find a match. Dunno what to make of it!0
The Elecraft tuner and amp really are wonderful pieces of equipment. I've had mine for a few years now and use them both nearly every day. Just be really careful not to accidentally overdrive your amp as there is the possibility of taking out the PA and that would be a very expensive mistake.
Rob,
After you train the tuner, place it in MAN mode. It will grab the correct ind/cap for the frequency and then that is it. Even if the SWR is high, it will NOT try to auto-tune again. It works flawlessly for me anyway. It is a much nicer solution than any other auto-tuner that I've used to date.
Very interesting, I'll give this a shot Norm. Thanks for the advice.0
Rob,
Like Norm I'd read that the tuner plays nicer in 'MAN' mode once tuned/trained. Seems counter-intuitive to leave it in a mode called 'MANUAL' but I guess once you've trained it, it isn't really manual....
Paul let me get back to the house and check all the settings. I seem to remember futsing around with it a bit before it started working consistently. I am confident we will get you running good
Thanks Chris. Bedtime here in UK, so I'll check in again tomorrow. Cheers. Paul M0CVX0
@Chris N6WM. Chris, I've cracked it....noticed that the KAT500 Utility was polling at 38400, so that's what I set up in SSDR, Settings, USB Cables. Now it works. Not sure if it should work at all speeds, or if 38400 is the preferred. I wonder if the USB Cable documentation could be improved in this regard? 73 Paul M0CVX1
great! Glad its working. I think the baudrate needs to match whatever the device is setup as. Anyway glad you are up and running!0
- 384 Community Topics
- 648 The Flea Market
- 149 SmartSDR+
- 262 SmartSDR CAT
- 961 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
- 142 Amateur Radio Interests
