WSJT-X Only Transmits If I click "TX Next?"
Moose
Moose Member ✭✭
edited June 2019 in SmartSDR for Windows
I'm using a Maestro and FLEX-6500 with WSPR. It all works great excpet for one issue. I can only get it to transmit if I click "TX Next." The "Enable TX" button is red and I have Tx Pct 20% set. I had this running all night last night and it didn't transmit one time. Anybody else have this issue?
73 Chris AK4SK
  • Jay Spaulding
    Jay Spaulding Member
    edited February 2017
    pretty sure thats why it works. You have to have them set that way no matter what radio version you are using.
  • Moose
    Moose Member ✭✭
    edited October 2017
    I don't understand what you're saying. My radio should be automatiicaly transmitting 20% of the time if Enable TX is selected (which it is) and listening 80% of the time. It is not. It only transmits when I click "TX Next." To get it to transmit again, I have to again click "TX Next." In other words it is not automatically transmitting as it should.
    73 Chris
  • AH0U
    AH0U Member
    edited June 2019
    Is your VOX on???
  • Moose
    Moose Member ✭✭
    No. I'm using SmartSDR CAT for PTT.
    I use the same program and same configuration for JT65/JT9, no issues.
  • Bob - G3WKW
    Bob - G3WKW Member ✭✭
    edited October 2017
    Does the WSJT-X log screen show that it has tried to transmit? It may require a selection in setup to enable that.
  • Moose
    Moose Member ✭✭
    Bob,
    Do you mean the main window that shows thew time, signal strength, freq, call, etc. of received signal in a text format? If so, no, only if I have clicked TX Next.
  • Bob - G3WKW
    Do you have band hopping checked and if so have you edited the schedule correctly, bands could be set to Rx only.
  • Moose
    Moose Member ✭✭
    Bob,
    I think that was the issue. I had RX Only selected for all frequencies. Let me give it a few minutes and see if it TXs.
    73 Chris
  • Moose
    Moose Member ✭✭
    That did it, working great now. I figured it was something I did!
  • Carl N8VZ
    Carl N8VZ Member ✭✭
    edited June 2018
    You also have to click Enable TX.  I know it would seem that just clicking TX next would work, but you need to have both buttons clicked.  I learned this from experience.  -- 73 de Carl N8VZ
  • Moose
    Moose Member ✭✭
    Yeah I had that checked/clicked. That is what was confusing.
