Beta and WSJT-X
Yes, did so when 1.7 was released much improved decoding.0
Remember there is only one selection for transmit side, look at the earlier post by Jay.0
Thanks Pat,
I solved that problem by following the instructions that I received early this year from Dudley at FRS. I took notes from his explanations and came up with mine: "How to Correct DAX Errors in Audio Input & Outputs" for dummies: Which I must add, is much easier to follow than the one from Tim at FRS. (In my opinion)
For example:
How to uninstall SmartSDR and delete DAX errors
(In Control Panel) open > Device Manager
a. Check Audio Inputs and Output: see if any ghosted DAX drivers are left in the sound device.
b. If there are any DAX drivers; they should be uninstalled, one at a time.
Etc...
I emailed Tim, and enclosed the Word document above; asking him for suggestions or necessary corrections to make it available for those of us who are not that technical savvy in the forum: When it comes to getting around the computer.0
- 636 The Flea Market
- 144 SmartSDR+
- 261 SmartSDR CAT
- 199 DAX
- 45 Aurora
- 957 Maestro
- 57 FlexControl
- 931 Genius Products
- 302 Shack Infrastructure
- 141 Amateur Radio Interests
