JTAlertx was working OK but now gives "Error Allocating Memory" error
Patrick
Member ✭✭✭
JTAlertx "Error Allocating Memory" error while it is starting up, does not pull up config file. Anybody have this problem. I am using Flex6500, with WSJT-X, DDUtil, Log4OM, and JTAlertX. All was working well until, I started trying to get DM780 and also HRDlog functioning. How do I fix Error Allocating Memory problems. Is this related to the HRD, HAMApps feud. I have tried de installing JTAlertX, then reinstalling. HELP!
Hi Pat... I notice HRT V6 logging is no longer supported by JTAlert starting with 2.9.0. 2.8.7 is the last version that supports HRD V6 logging.
It appears HRD V5 is supported.
Not sure this is your problem but it might be related. I found this information on hamapps.com.
Kev
Using Log4OM.... for at least 3 weeks, I was thinking that it is something to do with the SQLite DB that is not allowing JTAlert from accessing the DB. JTAlert will load until I think it reaches the DB entry. Just a theory, Still need some clues. Only HRD app I tried using was DM780. Need some clues how to fix this. Thanks for the comment.
Pat0 -
Solved, permissions were **** up somehow in the SQLite DB. Also checked and made to mach the permissions in JTAlertX. Been working on th is for 2 days...1
Excellent!0
- 113 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
