Flex-6500 anomaly disconnection
iz7auh
iz7auh Member ✭✭✭
edited November 2019 in SmartSDR for Windows
Good morning, my flex 6500 is suffering from a strange anomaly, suddenly for masterstroke connection, not responding is not detected, they are forced to make a forced shutdown of it, I tried both ethernet / wi-fi connection I use last version 1.10
  • Lawrence Gray
    Lawrence Gray Member ✭✭
    edited January 2017
    I have had this issue 3-4 times since updating to the latest version.  I leave the radio running and come back to find a disconnect message on the screen.  I try to reconnect and the radio is not found.  Hard restarting the radio "fixes"the issue.
    Seems too intermittent to determine the cause.
    Larry, W1IZZ
  • James Del Principe
    James Del Principe Member ✭✭✭
    edited January 2017
    it seems to happen when the radio and computer have set idle for some time. Then the message appears.      73, Jim
  • Ria
    Ria Member ✭✭✭
    There have been some reports of when your router renews DHCP that this may cause a disconnect.
  • Lawrence Gray
    edited January 2017
    Interesting.  In my case, no DHCP since the update to allow static IP's in the Flex.
  • Ria
    Ria Member ✭✭✭
    edited January 2017
    Not just your flex but also your maestro and/or client PC.
  • iz7auh
    iz7auh Member ✭✭✭
    edited January 2017
    Now try to set static IP.... stay tune
  • Lawrence Gray
    edited January 2017
    No Maestro and the PC is also static.
    edited January 2017
    Would a router renew DHCP while the radio and computer are both connected and running?
  • Ria
    Ria Member ✭✭✭
    edited January 2017
    well in that case it may be something else but I know some here have had DHCP related issues.
  • Ria
    Ria Member ✭✭✭
    edited January 2017
    Yes, it would renew DHCP leases at expiration, regardless of what is running.
  • Moose
    Moose Member ✭✭
    edited October 2017
    I have this issue as well. I have been assuming it is related to a similar issue I have with the Maestro restarting (which I understand to be the firmware in the radio itself resetting).
    73 Chris AK4SK
  • John - K3MA
    John - K3MA Member ✭✭
    edited April 2018
    Same issue here.  No Maestro and Static IP's.  Never did it before and 3-5 times since upgrade.
