DIV antenna selection
AH0U
I would like to use my RXa antenna as part of the DIV option but RXa is not a choice on the pull down... any thoughts on adding additional choices to the menu for the 6700???
RXa is a choice for DIV if you are using ANT2, and RXb is for ANT1.0
If RX-A is not an option, it is because that port cannot be used for that slice (SCU).0
I don't understand... can you be more specific... tnx0
Essentially if an antenna port is assigned to an SCU (digitizer), then that antenna port can't be used for assignment to a different SCU. Some ports, like RX-A and RX-B have a direct relationship to SCU1 and SCU2 respectively.
I suspect ANT-1 on the parent slice is connected to SCU1 which is also directly connected to RX-A, making RX-A not available for the child slice.0 -
Got it .. TNX this will take some rethinking as my RX ant. Is on RXa so I guess I could set slice B as my TX active and then use RXa for the DIV combo.... I'll play with it0
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
