Focus Helper and SD Contest Logger
K1ESE
Member ✭✭✭
I would like to use the Focus Helper feature of SmartSDR with my preferred contest logging program SD (ei5di.com).
I have been working with the developer, but no luck so far.
SD is written in PowerBasic in the console mode so there is some question what the name property is for the SD.exe window. The title bar just says SD. We've tried many different variations in the SmartSDR Focus Helper configuration - SD, SD.EXE, C:SDSD.EXE and so on. No luck.
Suggestions appreciated.
73 de K1ESE
John
73 de K1ESE
John
What is SDR Focus helper??0
It's in the Radio Setup screen of SmartSDR under the Radio tab. It helps to return focus to your logging program or other application after you use the mouse to interact with SmartSDR.0
I you happen to have 'autohot key' installed. use the 'window spy' function to maybe get a clue..
AL, K0VM
Tnx 73 AH0U0
Al -
I don't have Autohotkey.
I am suspecting that the Windows name property may be optional for programmers and, thus, there is nothing to find.
John K1ESE0
- 338 Community Topics
- 607 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 170 SmartSDR for Maestro and M models
- 401 SmartSDR for Mac
- 264 SmartSDR for iOS
- 247 SmartSDR CAT
- 185 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 19 Aurora
- 190 FLEX-8000 Signature Series
- 913 Maestro
- 886 Genius Products
- 320 Tuner Genius XL
- 116 Antenna Genius
- 281 Shack Infrastructure
- 197 Networking
- 137 Contesting
- 741 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 954 Third-Party Software
