SmartSDR and Easypal
W3EX -- Tom
Is there any new information on selecting RX and TX ports in EASYPAL? DAX RX and DAX TX do not show up in the EASYPAL setup.
Happy new year, Tom!
EasyPAL newest edition October 2014
http://www.vk3evl.com/index.php?option=com_content&view=article&id=57:easypal-downloads&...
I run EasyPAL like this:
You see that DAX Audio TX shows, but DAX Audio RX1 doesn't in this list of 11 soundcards!
No problem: Just select DAX channel 2 both in the slice and the DAX control panel and set
EasyPAL to DAX Audio RX 2.
Hope this works,
73, Alex - DH2ID0 -
Yes that did work for receive. How about TX?
Thanks very much.
You need a PTT port in SmartSDR CAT which you can set in EasyPAL like this:
Sorry that it is in German, but you surely can get the right
settings.
My PTT port is always 7.
73, Alex - DH2ID0 -
I having the same problem with receive audio not getting to Easypal .
I have DAX set to channel 2 and can see the audio on the DAX popup
but not getting any audio into Easypal , tried different version of Easypal
using Win10 , but have tried on another computer with Win 7 and still I can't get to work
I can get transmit to work using VOX as I haven't got to setting up the Cat control for Easypal yet.
I had easypal working on my Flex 3000 when I had it.
I can get Fldigi to work Ok
Ray WB0HHM0 -
"I can get Fldigi to work Ok"
At least that narrows down the troubleshooting to Easypal0 -
Yes it seems that way, the fellows above seem to have it working , maybe a setting in Easypal that I am missing?0
This is very similar to my experience with my 6500 and easypal. I have given up at this point. Fldigi, HRD etc all work well.
Tom thanks for the information What version of HRD do you have and will it do what Easypal does?0
USE KENWOOD enter commport from Smartsdr Cat that uses PTT
This always pops up and is not a concern .This does not stop the operation just click ok and go.
It will happen everytime you use Easypal.
HRD does not do what easypal does. I was just saying that I could set up HRD to work fine. I think there is something strange in Easypal that does not show all of the DAX circuits.0
I finally got it to work the information from AA0KM did it for me Thanks Mary0
- 245 Community Topics
- 490 The Flea Market
- 7.4K Software
- 327 SmartSDR for Mac
- 243 SmartSDR for iOS
- 224 SmartSDR CAT
- 163 DAX
- 347 SmartSDR API
- 8.5K Radios and Accessories
- 767 Maestro
- 42 FlexControl
- 727 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 222 Shack Infrastructure
- 149 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
