SDR Bridge : No width to the stream ?
Andrew O'Brien
Andrew O'Brien Member ✭✭✭
edited November 2019 in FLEX-6000 Signature Series
I continue to be frustrated by the quirks of SDR Bridge , perhaps it is all pilot error however. Today all seems to be working well except on 20M where the lower and upper range of the specified stream frequencies is the same!  Thus, I assume, no skimming of anywhere but the precise frequency. Zooming in/out does not change this range.   I seem to not understand how or if the actual stream range can be changed by the user.  It does vary, so I assume the user can have some control over this feature
A screen capture of SDR Bridge can be seen at https://youtu.be/NYH4CHlIfCE to help illustrate my issue.
Andy K3UK.
  • Ria
    Ria Member ✭✭✭
    Hi Andy, That seems odd as I can skim up to 192khz of spectrum. Is your DAX I/Q set up properly? The 6300 is limited to 96kHz I believe.
  • Andrew O'Brien
    edited January 2017
    SDR Bridge has generally caused me all kinds of grief in the past few months, so it is hard to say. DAX/IQ appears to be set as per instructions.
