Profiles will not export on my Flex6300 using the Export profile feature
Barry J Cohen
Trying to save my profiles using export function and keep getting errors. I did turn off antivirus first per previous notes on group still get errors?
error's include:
Ionic.zip.zipException:Cannot read that as a Zip File
System.BadImageFormatException BadIL Range at Ionic.Zip.Aip Entry?
N2BJ
error's include:
N2BJ
Barry... in the export tab you can select what gets exported. I wonder if a corrupt profile is causing your problems. What happens if you select one single item for export? If that works, maybe add more items until you come up with the offending piece and troubleshoot from there?
I just did a full export, 6500 with version 1.10.8 and didn't get any errors. I believe the ionic is a library used to compress (possibly encrypt) the exported profile.
Kev K4VD
Perhaps, re boot the radio, and let it build a new file.0
Thanks to all it was a problem in the Memories file. I unchecked memories and it exported fine.0
- 113 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
