60m for Powersdr 2.7.2
Uwe Sievers
Uwe Sievers Member
Since 3 days we have a new band on 60m in Germany. I need a solution for my Flex5000 to operate there. Actual version is 2.7.2.
  • Geoff
    Geoff Member
    edited December 2016
    Hi Uwe. You need a turf file from Flex. You need to raise a ticket with them and ask for a file for Germany. They will need your callsign and the serial no of the 5000a, this is on the back panel and also your database. Do this by Opening PowerSDR Setup and export your database. Then attach that database to the Support request ticket. I think that covers it. If I've forgotten anything I am sure they will tell you.
    This is the link, https://helpdesk.flexradio.com/hc/en-us/ Click on the first item under announcements, set up a ticket. You will receive a zip file. Follow the instructions carefully and all should be ok. Look forward to talking on 60. 73 Geoff G4XMJ
  • Uwe Sievers
    Uwe Sievers Member
    Thank you Geoff  will do so   Merry Christmas
    Uwe DJ9XG
