Maestro won't turn on
Rory - KN5D
Maestro won't turn on. The AC adapter has been plugged for several days. There is no USB battery.
Have you had it working before?
Did you press the power button and hold for ~5 seconds? You should feel a little "click" when the button is fully engaged. You might need to press harder.
73 Martin AA6E0 -
Rory
Echoing Martin:
Press the power button down for @ 5 seconds. You should first see the screen go from blackest black to a nearly identical but imperceptibly brighter shade of black, (you can release the power button when you see this change) it's the touchscreen powering up. Next, the Maestro begins it's boot up sequence, Wait a while and you "may" see the Maestro splash screen momentarily along the way to the radio selection or wireless selection screens. Mine often goes straight to connected and already running, all by itself now, after the most recent software upgrades.
My guess is your not holding down the power button long enough.
You would likely already be aware of all this if it had ever worked for you before.
I think it's intentionally designed this way to avoid accidental power ups when stored in things like backpacks, go boxes, etc. It would be a shame to hike it in 5 miles uphill, only to find out the battery was being drained while you were bouncing along.
If it worked fine in the past, and you already know all this, sorry for wasting your time.
SDRgadgets73, Jay - NO5J
I have converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution. Please respond using the HelpDesk ticket for issue resolution.
- 368 Community Topics
- 625 The Flea Market
- 8.1K Software
- 74 SmartSDR+
- 421 SmartSDR for Mac
- 270 SmartSDR for iOS
- 189 DAX
- 33 Aurora
- 238 FLEX-8000 Signature Series
- 937 Maestro
- 54 FlexControl
- 913 Genius Products
- 331 Tuner Genius XL
- 122 Antenna Genius
- 293 Shack Infrastructure
- 449 Remote Operation (SmartLink)
- 773 Peripherals & Station Integration
- 991 Third-Party Software
